Originally Posted By: DragRace
It'll work perfect for regular wheel bearings on a vehicle as NLGI #2 is the primary wheel bearing recommendation.
Not quite. GC is the National Lubricating Grease Institute certification for wheel bearing grease. (LB is the chassis lube, and many greases are marked LB-GC.) The #2 is the consistency of the grease. #1 is softer and #3 is firmer. #000 is almost liquid and #6 is solid.
