My parents had 3 TJS (Envious as they are my favorite Jeep after the XJ). 97, 01 and 04 Rubicon. All with manual trans. The NV transmission had way more gear noise than the AX-15
We had one of the first TJs around. The revolutionary coil sprung wrangler got a lot of attention. The 97 had 3.07 gears and was a dog on the highway with 4 people and luggage with the but never had a single problem with it.
The 2001 was very problematic. 3 radiators, the right rear wheel would always lock up, it had to go to the dealer to get the computer reprogrammed every month otherwise it would run so rich it wouldn't even start. That thing went through like 20 sets of spark plugs in the 3 years they had it. It wasn't too bad on the highway as they ordered it with the towing package and got 3.73 gears.
The first week they had the 04 it ended up getting a new transmission. They drove it home, saw ATF leaking out of it. The dealer told them to bring it back because there was NO atf in it. Turns out the manual trans leaked dry and burnt itself up. After that, it was completely problem free.
I think the worst thing that happened with the JK was we were going to see my grandmother in the hospital and the Sentry system kept messing up and shutting the Jeep off ... in the country in a snowstorm.
Other problems:
- Electronic axle locks NEVER worked except once ...(rubicon model)
- Rear axle lock decided to lock going 55 on some back roads in the rain. (20K miles)
- Electric swaybar disconnect NEVER worked
- Engine started drinking oil at 30K (ended up at 1 qt / 600 miles when they got rid of it)
- Engine started knocking at 50K miles
- Sentry system would shut the vehicle off while driving (replaced module under warranty)
- 3 sets of axle seals
- CV driveshaft blew up (they don't off road it)
- Rear Dana 44 had to be rebuilt at 60K miles (they don't off road or tow ...)
- Front left and right rear calipers decided to start hanging at 35K miles for no reason.
- Electronic throttle body would often become responsive
- Vehicle could NOT go 55 in 6th gear on the flat (stock unmodified rubicon)
To keep up with traffic in the TJ Rubicon, you'd only have to shift at 2500RPM ... and that was driving it hard. The JK would have to be wound up to 4500 in order to get out of it's own way. That's why I never understood why people say the 3.8 has the same low end torque as the 4.0
My Cherokee certainly has its problems. It has 120,000 miles. It was totaled in a head on collision when it was new. I offroad the thing stressing the unibody and suspension. It's been jumped. It's been in mud. I tow and haul stuff with it all the time. It also sits for weeks at a time.
Other problems:
