Is it acceptable to run 5W-30 oil in an older vehicle that specs 10W-30?
Will it harm anything if I run 10w-40 or 20W-50 in an older 5.7L engine that specs 10W-30? I've noticed the oil pressure light flickering on and off with the lighter oils, but the heavier grade oils will keep it from doing this. I know, I'm fighting symtoms and not the cause, but I just don't have the money to repair/overhaul the engine on this old truck.
