Originally Posted By: tpattgeek
Originally Posted By: JOD
I'm kinda surprised by some of the comments. When I do a coolant exchange or a water pump replacement, I use a vacuum tool to refill the coolant so there's no air in the system--and I'm just some shade-tree home mechanic. Are shops really just overfilling and hoping that it "takes care of itself"? If so, that seems pretty unprofessional to me. I mean, the average consumer isn't going to be religiously checking the coolant after the repair, even if instructed to do so.
Using the vacuum tool there's no perceptible dropping of the coolant level. I overfilled mine the last time I did it--and I sucked out the excess.
No, I think this is different. I don't think they just filled up radiator and reservoir and called it a day... I believe they followed the proper bleeding procedure, and THEN added an additional amount just in case there is air still hanging around. There really is no bleeding on this vehicle. You fill the radiator, start it up, keep filling the radiator as it cycles through, let it warm up, make sure it's full, done. Then fill the reservoir. I guess they just added a little extra just in case. The level has been consistent since I posted this, so they must have done a good job bleeding.
When there is no bleeding procedure a trick I use is to slightly elevate the front of the vehicle to make the radiator and hopefully the fill neck [depending on design] the highest point of the engine. That helps to get some of the air trapped in the system out. I always put a little extra in the recovery system even after bleeding the system and keep an eye on it. Once I'm sure there is no air in it I remove any extra A/F, or top it up to the cold full level after the car sat overnight on level ground.
