Just a heads up for those interested. We have a new QT in the KC area in Olathe (119th st west of I-35) that has RED pumps. These pumps are only for non-ethanol 87 octane gasoline. They are labeled as E087. They are on the same islands as the regular pumps but you can only pump one grade through these red hoses.
Not sure if this is a trial run or if they will be rolling them out all across the metro, but keep an eye out for them and use them if you want to avoid ethanol.
