Fishing reel drag grease
by bernau
07/29/16 04:26 PM
Sulfated Ash, wt%, ASTM D 874 test questions
by mbacfp
07/29/16 04:02 PM
HD radio
by 007
07/29/16 03:51 PM
Front end repair
by possum328
07/29/16 03:49 PM
Purolator 10111 Red Can
by FordBroncoVWJeta
07/29/16 03:30 PM
Carquest #R85372, 2013 E-250 van, 4,500k
by car51
07/29/16 03:03 PM
Strange failure: Starter AND flywheel cogs ripped
by lars11
07/29/16 02:22 PM
My email from Castrol about Magnatec
by Tech819
07/29/16 02:13 PM
Audi 5000 / Known Stop-Leak Compatible w/ CHF 7.1?
by Miles07PT
07/29/16 01:41 PM
Observations on Workplace corrosion
by Vdubuk
07/29/16 12:15 PM
Oil filter change NIGHTMARE
by MetalSlug
07/29/16 12:08 PM
First time flushing an 05 Tacoma
by Back40
07/29/16 11:53 AM
_hashtagusername, larrybroad123, dr_p, CapHead, rowebil
58632 Registered Users
85 registered (2oldtommy, 440Magnum, Al, 97f150, 901Memphis, 8 invisible), 2105 Guests and 12 Spiders online.
58632 Members
66 Forums
252411 Topics
Page 1 of 2 1 2 >
#3048204 - 06/28/13 10:47 AM 6.2l diesel filter setup and oil ideas.
Biggles Offline
Loc: Central, IL
Ok so I think I've got an idea on what Im doing with my CUCV I'm going with an amsoil remote single bypass and a trans dapt full flow dual remote bypass. I'll probably add a thermostatically controlled oil cooler sometime in the future, now in the interest of extending my oci I'm trying to decide what the best oil for me to use is, I think Synthetics can last longer but I'm not sure that is the correct way to go for this old engine. Based on my searches ai know this is a frequent debate so I'm not expecting a definitive answer more the pros and cons of my different options.
1985 M1009 CUCV 6.2L 20,xxx miles (on the motor)
1982 VW Rabbit 1.6L 300,xxx miles
All Diesel. All the time!
#3048206 - 06/28/13 10:50 AM Re: 6.2l diesel filter setup and oil ideas. [Re: Biggles]
bullwinkle Offline
Loc: Cincinnati, OH, USA
Dumb question-don't the CUCVs come with a factory oil cooler? The LD 6.2s had them in the radiator, HD 6.2s (like the '93 in my sig) had an air cooled oil cooler in front of the radiator.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 15 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(CQ Blue)
#3048296 - 06/28/13 12:02 PM Re: 6.2l diesel filter setup and oil ideas. [Re: bullwinkle]
Biggles Offline
Loc: Central, IL
Yes they have one built into the radiator, I'd be running an additional oil cooler in the interest of getting my capacity up and allowing me to better control/fine tune my oil temp as in not running it through the cooler in the winter or when the engines warm.
#3048437 - 06/28/13 01:42 PM Re: 6.2l diesel filter setup and oil ideas. [Re: Biggles]
A_Harman Offline
Loc: Michigan
Do you have an oil temperature gauge? Since you already have an oil cooler on the CUCV, it may be a waste of time and money to put another one on if the existing one is providing oil at a safe temperature. It's hard for me to believe that an old GM 6.2L diesel can overheat the oil.
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
#3048478 - 06/28/13 02:34 PM Re: 6.2l diesel filter setup and oil ideas. [Re: Biggles]
SteveSRT8 Offline
Loc: Sunny Florida
^^^The above is excellent advice.
All our fleet trucks (gas) run the oil through a radiator cooler. But it is as much a heater as a cooler, ensuring that the oil gets hot enough as well.
Very important if you have a large HD radiator.
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
#3048599 - 06/28/13 04:31 PM Re: 6.2l diesel filter setup and oil ideas. [Re: A_Harman]
Biggles Offline
Loc: Central, IL
Fair enough, I wasn't planning on installing a cooler now anyway, and I guess instead of doing a cooler and guage at the same time I should probably start with a guage then start making decisions. H
#3048605 - 06/28/13 04:39 PM Re: 6.2l diesel filter setup and oil ideas. [Re: Biggles]
Biggles Offline
Loc: Central, IL
So I think I am going to go with the Amsoil BMK30 single remote bypass kit and I'm still trying to figure out the correct adapters to attach it to my motor. I will probably use whatever cheap full flow dual remote mounting bracket I can find and the appropriate adapter to replace my stockoil filter. So if I'm picturing this correctly I would have a bypass adapter on the block and then my full flow remote filters adapter on top of that. Or would it make more sense to just run the dual remotes and add the single bypass onto one of those filters? Any recommendations on brands or suggestions before I buy? Is the top dawg bypass better than amsoils?
#3048712 - 06/28/13 06:41 PM Re: 6.2l diesel filter setup and oil ideas. [Re: Biggles]
Biggles Offline
Loc: Central, IL
I've settled on the perma-cool full flow dual remote setup I found a deal I couldn't pass up. Now what bypass to run with this.......
#3051077 - 07/01/13 03:41 AM Re: 6.2l diesel filter setup and oil ideas. [Re: Biggles]
oil pan 4 Offline
Loc: Hampton, VA
Does your 6.2L have a turbo?
Heavily modified 1984 6.5L suburban.
#3051877 - 07/01/13 07:36 PM Re: 6.2l diesel filter setup and oil ideas. [Re: Biggles]
bullwinkle Offline
Unless he's added one, it doesn't-and given that model year's tendency to crack blocks (I had an '85 6.2 with cracked block main webs with only 110K on the engine), I wouldn't recommend one. Unless you have the '82 red 6.2 block, or the late 6.2 599 block built in '92 & '93, they can be a little weak (IMHO).
#3067800 - 07/17/13 07:56 AM Re: 6.2l diesel filter setup and oil ideas. [Re: Biggles]
Biggles Offline
Loc: Central, IL
No mine doesn't have a turbo, I would love a turbo but for the reasons listed above my truck is remaining N/A if I wanted a bunch of power I'd either swap to gas or a cummins. It works fine for me and it gets good mileage (for a heavy 4x4) I'll increase my air intake and potentially the exhaust but not much planned for power increases, mostly planning on durability and efficiency.
#3067991 - 07/17/13 11:33 AM Re: 6.2l diesel filter setup and oil ideas. [Re: Biggles]
Jim Allen Offline
Loc: NW Ohio
As an aside, at moderate fuel and boost settings, the turbo 6.5L had better reliability than the NA 6.2 and 6.5. Why? Yes, some of that was improvements in the engine structure but equally it was that the turbo engine produced adequate power. The NA engine is a slug, so to get the performance, you have to flog it everywhere, all the time. This was more an issue with people that worked their trucks hard, namely the 3/4 and 1-ton crowd that towed near at or over their GCVWR. I put a Banks kit on my '83 Blazer 6.2 and it was wondrous. No reliability issues at all during my ownership.
At about 160K miles, I rebuilt the engine and bored it 0.030." Add a bunch of performance stuff to it as well, which raised boost and fuel rates and power output. Still fine under my ownership, but the guy I sold it to blew it up. He bragged about doing 90 mph in it hour after hour. Thing is, it had a 700R4 and 4.88 gears with 35 inch tires then. The 700R4 is a TV controlled trans, so basically with lots of pedal applied, it never shifts up into overdrive. You can do the math but at the reported 90 mph in direct, the engine was spinning at upwards of 4,000 rpm. Hour after hour. Unfortunately, I had the pump guy set my governor up to about 4300... IIRC. That was mainly to facilitate some dyno testing, which consists of short runs at speed only (and then only to 4K rpm fer Pete's sake) Driving like that was not something I anticipated doing. But I have digressed.
Jim Allen
Keepin' the Good Old Days of Four Wheeling Alive
#3069213 - 07/18/13 01:22 PM Re: 6.2l diesel filter setup and oil ideas. [Re: Biggles]
bullwinkle Offline
Jim-did he grenade the crank on your '83? The cast cranks (and block main webs) were a known weak link on those, if I was crazy enough to try to make big power on a 6.2 or 6.5 I would spring for the newer forged cranks (that will fit the '92 & up 6.2/6.5s). My '93 non-turbo 6.2 does OK, but even a 4BT would outpull it easily!
#3070186 - 07/19/13 11:47 AM Re: 6.2l diesel filter setup and oil ideas. [Re: Biggles]
Biggles Offline
Loc: Central, IL
I really like the idea of an ATS turbo but I think my money and energy will be better spent on a 4L80E, I won't be running 90mph in it but I'd really like to have an OD to drop my highway RPM's. If I found an ATS turbo on the nets for a good price I'd get it but they are as rare as hen's teeth anymore and getting less everyday.
#3070339 - 07/19/13 02:34 PM Re: 6.2l diesel filter setup and oil ideas. [Re: bullwinkle]
Jim Allen Offline
Loc: NW Ohio
What happened was that the block cracked in a cylinder, from the deck right to the bottom of the bore. It was on the outer facing part of the cylinder. I only saw pics. Some have said maybe I bored it too much (0.030") and maybe there was core shift. That's possible but I was watching and photographing the machinist as he sonic tested the bores and they were right one before and after the boring. Likely an unseen materials flaw. The guy bought a reman engine which failed spectacularly (thrown rod) six miles into the first test run. I still contend that I would likely never had a problem the way I drove it but who knows. It did about 200 hp on the chassis dyno with moderate fuel settings and about 14 psi boost.
Jim Allen
Page 1 of 2 1 2 >
