We have a 55 gallon fish tank that has a florescent light on the top that originally had a T10 40w bulb in it. The light stopped working so I went to get a replacement bulb locally. Checking all around there were no T10 bulbs to be found. After checking Lowe's, Home Depot, ACE and even a local lighting supply company I went to our local pet shop who said that as long as the wattage is the same a T8 bulb will work in a T10 light.
I put the 40w T8 bulb in the light and when I turn it on just the edges glow a very dim light and occasionally flashes. I don't have any other lights to test the bulb in. Should I order a T10 bulb online, or does it sounds like it is a problem with the ballast in the light and I should just get a replacement light/bulb?
