'91 Mazda B2600i transfer case and trans oil?
by Jason280
06/28/16 03:59 AM
How to cut power to breaker box ?
by Merkava_4
06/28/16 02:21 AM
Spark plugs in hi-per applications
by mjoekingz28
06/28/16 01:07 AM
OK, before I lube it ...
by BrocLuno
06/28/16 12:53 AM
Toyota Japan Fluid SDS
by SXE10
06/27/16 11:28 PM
Online Oil Viscosity Selectors
by Merkava_4
06/27/16 11:25 PM
Considering a differential swap
by buck91
06/27/16 10:18 PM
HVAC Evaporator Cleaning Results
by sleddriver
06/27/16 09:51 PM
Car Acronyms
by Marco620
06/27/16 09:46 PM
Vibration with new tires - your thoughts
by Bandito440
06/27/16 09:41 PM
Carpet cleaning methods.
by Run
06/27/16 09:26 PM
Fram XG16 4522mi 5.7 Hemi
by AntsinmyEyes
06/27/16 09:26 PM
peg, CornbreadMan, JoelB, alostaunau, alanwayne1908
58295 Registered Users
39 registered (alarmguy, 2015_PSD, AZjeff, AirgunSavant, Bandito440, BeerCan, 4 invisible), 1063 Guests and 13 Spiders online.
58295 Members
66 Forums
250918 Topics
#3016387 - 05/29/13 12:07 AM My 2001 Passat 1.8t Frantz install pics
zanzabar Offline
Loc: NorCal
Mounted the Frantz filter on this engine for two purposes: 1) clean out debris from engine rebuild and spun bearing, and coke (aka "turbo turds") built up during sludge issues from general neglect by previous owner; and 2) to increase oil capacity and cooling when hot (has low oil pressure issues).
It just barely fit under the coolant expansion tank and I mounted it to some vacant holes on a bracket that supports the coolant tank and some misc wires.
Oil cooler in view at left - brass fitting on the bottom left of it goes to oil pressure gauge, brass fitting on the top goes to Frantz filter.
The filter.
The return goes to filler cap.
And despite the fact that the filler cap is not far from the PCV port there doesn't seem to be any extra oil going into PCV piping.
The attachment to the filler cap is clearly not the most elegant setup, but I made do with what I had available and it seems to work.
2007 Volvo V70 (115k miles)
2014 Ford Focus (14k miles)
#3016396 - 05/29/13 12:41 AM Re: My 2001 Passat 1.8t Frantz install pics [Re: zanzabar]
JAG Offline
Loc: Fredericksburg, VA
That's cool. Did you idle the engine while watching how fast the oil flows out of the return line? I'm curious if it's more of a drop...drop or a constant stream. Thanks for sharing!
2015 Dodge Challenger SXT - Super Track Pak
#3016429 - 05/29/13 04:29 AM Re: My 2001 Passat 1.8t Frantz install pics [Re: JAG]
Ducked Offline
Loc: Taiwan
Re the above post, if you have "low oil pressure issues", I think you'd want to keep flow through the Frantz very low, because, since its a bypass, it'll tend to lower your oil pressure further.
I understand that this can be accomplished by soldering up the oil return path and then drilling a small hole in the plug. I'd guess you'd start small and work your way up to what you want.
Apologies if this is obvious. Havn't done it, but have been thinking about it for a while.
#3016504 - 05/29/13 07:34 AM Re: My 2001 Passat 1.8t Frantz install pics [Re: zanzabar]
ET16 Offline
Loc: MD
What is that filter you have going to the coolant reservoir?
#3016583 - 05/29/13 09:17 AM Re: My 2001 Passat 1.8t Frantz install pics [Re: ET16]
zanzabar Offline
Loc: NorCal
Just a generic fuel filter from Autozone. This car's coolant system was neglected as well and I'm still trying to clean it out.
#3016585 - 05/29/13 09:21 AM Re: My 2001 Passat 1.8t Frantz install pics [Re: Ducked]
zanzabar Offline
Loc: NorCal
I have looked at the flow through the Frantz a few times and it is a steady slow stream, about 6-8oz per minute. It lowers oil pressure by only about 2psi. Still, with this engine I'm seeing 10-12psi at very hot idle which is lower than I would like, so to avoid the bypass' effect on oil pressure I may install a 25psi pressure valve in line so it doesn't filter except when the pressure is high enough.
#3018290 - 05/31/13 02:13 AM Re: My 2001 Passat 1.8t Frantz install pics [Re: zanzabar]
Ducked Offline
Loc: Taiwan
Good fix. Should have thought of that, though finding the bits for anything is a challemge here.
#3044782 - 06/25/13 03:13 PM Re: My 2001 Passat 1.8t Frantz install pics [Re: zanzabar]
zanzabar Offline
Loc: NorCal
I finally found a reasonably priced check valve to go inline on the oil return line. Just ordered it, will post pics when installed.
http://www.valvecheckinc.com/file/V000398-H6200merged.pdf
I'm getting the 1MM with 20psi cracking pressure, would have preferred something more like 25-30psi, but this will prevent oil shunting at hot idle at least.
