Originally Posted By: hypervish
Originally Posted By: Art_Vandelay
Originally Posted By: KitaCam
Thanks for this info...I had once recommended on Toyotanation that the cover be pulled, thinking (but not knowing for sure that there were 2) that the (front) valve cover would be easy and got criticized for that...nice to find out I was right...
As for the door...when I got my Camry the passenger door skin had been replaced withOUT the soundproofing foam pad attached to the inside and so it slammed like an aluminum storm door, a cheap one at that...adding the foam pad returned the "THUD" to the door so it now sounds more substantial, and "rich"...
Yes the timing belt is a bear and expensive...$1000-1200 if you change the water pump and seals...recommended...at the same time...but I've read that the new replacement is made from kevlar and will last a lot longer than the the original...so hopefully a one-time/100k maintenance...
The seating is high...you definitely feel that you're sitting ON the seat rather than IN it...much more family sedan-like (like the Camry) than sports-sedan...
All that said...it's a nice car...my cuz has the next gen convertable and it's sweet.
That timing belt job is really expensive. If I get the car I'll drive it around for at least a month and make sure it's rock solid before having it done.
I'm sorry but $1000-$1200 is pushing it.
You can buy a timing belt kit off of ebay (includes cam seals, timing belt, water pump, crank seal, water pump gasket, drive belts, and thermostat + gasket) for $300. You don't even need all of that at only 50k miles, you can get a kit with only timing belt and water pump for around $100 all OEM parts by the way.
Labor is going to be around $400.
$1000-1200 @ dealer including front seals, water pump, and drive belts...
a lot of information here...
http://www.toyotanation.com/forum/104-5t...iming-belt.html
