Continental Tire asserts that wider winter tires have several advantages:
........"Comparing winter and summer tires of the same size, winter tires are actually at a disadvantage in terms of cornering stability," explains Dr. Andreas Topp, Head of Winter Tire Development at Continental. "This is due to the softer rubber compound and fine siping of winter tires designed for driving on snow and ice. Fitting narrower tires further exacerbates this inherent disadvantage. In order to achieve the same level of cornering stability and steering precision as with summer tires, fitting wider winter tires is recommended.".................
"........Wide winter tires also offer advantages on typically wintry road surfaces. On compacted snow surfaces in particular, they offer more space to form sipe edges, fill deeper tire tread grooves with snow, and increase friction between the rubber and snow. The handling properties of a car fitted with wider winter tires are also enhanced on compacted snow surfaces............."
".............Wide-base tires even offer advantages in deep snow: Their cornering stability is better than that of narrower tires and their braking distances are shorter. Narrower tires only have the advantage when it comes to traction in deep snow. ................"
(The above quotes are from a Continental press release entitled "Warm Slippers for the Colder Season")
