Originally Posted By: Hosteen
Thanks for the photos. Yes, I see what you are referring to as a second ADBV. Blocks the drain back through the discharge side of the filter. That would insure a full filter of oil at start-up.I wonder how much that valve cuts down on oil flow. Regards
I doubt the spring in the 2nd ADBV is very stiff, so it probably adds a few PSI to the delta-P across the filter.
You only "cut down" on oil flow when the positive displacement oil pump hits pressure relief. So typically, the flow oil flow will be the same because it takes rare occasions for the oil pump to hit pressure relief mode (ie, engine near redline, and/or cold thick oil being used).
