Stewart Fan
Thread starter
I can't remember the manufacturer of the trailer right off the top of my head. Its at my buddies house or I'd go outside and look.
I did buy mine at Lowes a few years back. It didn't have an A-frame tongue when I bought it,it had a straight tongue with a pin that allowed you to tilt the deck back like a mini dump trailer.
It was a rather flimsy design on an otherwise stout little trailer. I bought some angle and welded it to the tongue to make it an A-frame.
The tires on mine are 4.80x12 with a weight rating of just under 1000lbs. The trailer has a 2000lb Dexter axle under it,so the tires are sufficient.
I'd like to put some larger tires on it just for a bit more ground clearance. I take it camping or hunting and occasionally run into clearance issues on the logging roads.
