I am going to Steen Mtn backpacking, should be a blast. The trip is 800-900 total. I totally agree with the use of the motorcraft filter, ford will most likely blame the filter if there is an oil related problem and stick you with the repair. I admit I am impaired reading your responses since I am guessing what UOA, OCI and LOF means. Fuel dilution with this oil change might be a problem because this engine had a huge problem mostely within this oil change. I had multiple service engine now lights and check engine lights come on. I experienced terrible gas mileage, missing, huge rich idle, stalling all over the place, erratic transmission shift, slamming gears etc.... The Escape has been a total S**t show, sorry for my foul language but you would say the same if you owned this car. Anyhow, Ford finally replaced the main wiring harness under the hood and it fixed the problem. So I probably should dump this oil out before I go. So how and where do you have your oil checked. Thanks Alan
