I have four gearboxes that have different ratios and the one I love the most has a 2nd and 3rd gear whine. Recently I've replaced all the main bearings, seals and have measured the synchros, inspected all the internals and all the gears measure and look good. The oil I am using is what the gearbox manufacturer prescribes. All the obvious things are replaced and checked, but it changed nothing about it! I know for a fact that it is coming from the gearbox because if I swap it for one of my other gearboxes the noise is gone, but then I am stuck with close ratios and I love this wide ratio gearbox...
There is a lot to read on the internet about whining in gearboxes and I have experienced this on many of the cars I have owned and with the one I have now it is not bad enough to call it very problematic, but it just irritates me. In the past I have tried all sorts of prescribed oil additives and that never really worked. Also tried slightly thicker oil, but to my experience that only means that before it stops whining it already shifts like [censored] because synchros just don't like thick oil.
So I thought I can always replace the lot, or get another 100 euro gearbox and start all over, I decided to try something radical and have thrown a little whack of CV joint grease (MoS2) in it to both thicken the oil a little and modify the friction. To my surprise this removed about 80% of the whine! And that's not the only thing, it actually improved the smoothness of gear changes!
Now I just wonder how bad it is to keep driving like this for a while? How do I know if this grease contains ingredients that are bad for the health of the rest of the gearbox?
