I did a search on EOS being added to engine oil. I found people mentioning adding a few ounces to a whole bottle. Has anyone added EOS and had good results?
I will be breaking in my new Ford 300 with Rotella 15w40 or SuperTec 5w30 and was planning on adding the whole bottle of EOS for cam break in. Then after the first quick oil change after break in I will run Shell Rotella T 5w40 syn.
I also read an article in the June 2006 HotRod magazine about cam failures with flat tappet cams. They recommed EOS and Shell Rotella oil and Quaker State Racing oils.
Should I add EOS to my engine oil for break in?
Apparently breaking in a flat tappet motor with Rotella 15w40 is recommended. I'm a little worried about the 15 weight cold start. Any recommendations?
