With all of the friction parts of a trans such as the clutches and bands, is it still safe to use LC in the trans without causeing any slippage? LC promotes more lubricity, so i was wondering if this will cause problems with these parts and or the fluid and cause the trans to slip some. Has anyone used LC in their trans for an extended period of time without and effects?
Also same questions for a rear diff with Limited Slip? Can LC be used in a rear LS diff without affecting the function of the LS.
thanks for all the help. Want to make sure before I add any LC to my drivetrain that I am not going to regret later on.
