Thanks to new member 67King for the following:
http://www.lnengineering.com/joegibbsracingoils.html
As a disclaimer it should be noted that Lubrizol formulates the Joe Gibbs Driven motor oils.
This shear test is obviously tougher than anything one could subject an oil to in an actual engine that I know of. I've never seen M1 0W-40 shear down to a 20wt but that's what it did in this test.
What impressed me, was how much the VI of both oils rose as they sheared; to 224 for M1!
That is the only thing that concerns me with high VI oils; namely, loss of VI in service.
Viscosity loss happens for a number of reason, fuel dilution, high oil temp's and oil shear but if you have an oil pressure gauge it's very easy to monitor and thicken up the oil if necessary by adding something heavier. But loss of VI you can do nothing about short of dumping the oil.
The other interesting aspect of this test was the loss of kinematic viscosity vs HTHSV.
For M1 the HTHS viscosity loss was 44% less than the KV100 loss and 34% less for the Gibbs oil. This makes sense since M1 is formulated with more polymer VIIs.
Some may think this is strike against M1 but I don't see it that way.
We know from the dozens of UOAs of M1 0W-40 that it doesn't shear anywhere near that much in actual service, and I consider it still to be the benchmark 0W/5W-40 from which all others are compared.
