A few months ago, my brother purchased a 1986 Tiara 3600 Open. It's got 980 hours on each motor.
From what I've been told by the previous 2 owners (we are now the third owners), she's been on a steady diet of Mercruiser 25w40. I don't see much tarnish/gunk at all inside the filler caps. And since the oil was changed every fall, each OCI (27 oil changes on this boat) typically only had 30 hours on it...so I wouldn't expect much dirt either.
The Mercruiser 25w-40 oil has 1600ppm zinc from what I can find. But LOW detergency, and low boron and zero moly. Pretty bland stuff.
I'm responsible for maintaining this boat, and since finding BITOG, I'm having a hard time putting this Mercruiser oil back in her this fall.
Of course, it makes better sense to run a Dino SL/SM rated HDEO like Rotella, Delo, etc. But would you recommend a synthetic to clean up the internals a bit and keep this boat running at tip-top shape? Amsoil makes a decent Marine oil. What about running something like Pennzoil Ultra 5w40? Or even Red Line? I'm a little leary about running an ester based oil in a marine environment though.
Stick with the HDEO dino oil or run a synthetic? My brother knows nothing about engines and but runs synthetic in everything he owns. The price of the oil is of zero consideration for him. So, if price is to be ignored, what would you run?
