Interesting article:
Noria Article on Benefits of Bypass Filtration
Interesting that they peg filter size as an issue and we have seen a general trend towards smaller filters. I really like the big FL1A older Ford's used.
I am not going to bypass filtration because my engines last as long as I need them to and then some with the manufacturer's filter setup, though there is a benefit of longer oil life with better filtration.
Before adding a bypass filtration setup, one should consider the crud getting into your oil through the air filter. I suspect that some filter boxes are not necessarily perfectly sealed, especially on an older car.
