Nulon Long Term Engine Treatment is the ultimate in long-term, low-cost engine protection and friction reduction for petrol engines. Nulon E30 contains ultra-fine particles of Polytetrafluoroethylene (PTFE), which has the lowest co-efficient of friction known to science.
This unique formulation is blended with high-grade carrier oils and other proprietary performance additives. The end result is a product which, when used only once, will provide a residual low friction surface on all moving parts that will last up to 80,000 km (50,000 miles).
• Lasts up to 80,000 kilometres (50,000 miles).
• Reduces cold start-up damage as the PTFE coating provides adequate lubrication until oil pressure is attained.
* Extends engine life.
* Promotes a quieter, smoother engine.
* Improves fuel consumption.
* Reduces engine temperature.
* Is cost efficient.
Hi guy they are work for my car? honda accord? thanks
