Well said, Pabbs.
That's the problem with ALL of this stuff. We just don't know. I'm thinking it might be best to use an oil that has plenty of the additives you're looking to get with the VSOT instead of adding VSOT. In my old car, I know it smoothed out valve train buzz, but in a new car, I dunno, the stuff DOES thicken oil noticeably even at an ounce/Qt. You can see it in the rotation of the cams, the consistency on the dipstick.
I don't know why VSOT has to be SO THICK. Does that create a warranty issue? Who knows? I suspect the stuff won't kill your engine before the warranty is up, or ever, or it may be GOOD for the engine. But who determines that? And at what cost? Without a lot of costly oil analysis, you simply don't know what you've done til maybe it's too late. IF you sludge the engine early on with the stuff, you can BET they'll analyze the sludge when they get inside the engine, and how do you explain THAT? They tell you not to add stuff in the manual and warranty.
I haven't seen ANYONE here point to the stuff (or any of these additives to be fair to VSOT) and say, in a positive, educated fashion, that VSOT is GOOD for engines, and then back it up with controlled studies or empiracle proof supplied by engineers. Anecdotes, seat of the pants impressions, but PROOF? Fact IS, even Valvoline doesn't juice their oils with this stuff.
If the goal is the additives, heck, run Havoline Dino, it has the Moly, Boron, Calcium, some Zinc in abundance. I imagine there are iterations of Amsoil and others that have lots of chemistry in them to play with if you want to vary the additive package, and you'll not run afoul of the warranty.
Having just purchased a new car, I'm getting kinda hinky about tampering with the warranty with additives on second thought. I am changing the he11 outta the oil the first 5000 miles, but no more VSOT-adds to the thing until it has reached beater-status. Besides, run a Havoline or other oil with the same additive-package, and the VSOT becomes a bit, shall we say, redundant? Why mess with the viscosity when the manufacturer is so insistent on the subject?
Just my two cents, but Pablo makes good sense when he points up that we just do not KNOW. Everything else is starting to strike me as a crap shoot with this additive experimentation. I think I'm going to limit my experimenting to trying different oils and filters that meet grades and settings spec'd by the manufacturer.
THAT leaves a lot of leeway to play, yes? No?
