what are your thoughts about using 1/2" type M copper tubing, the type used in plumbing, to make a simple oil cooler? Specifically a remote power steering cooler where the system uses power steering fluid not ATF.
I assume the main reason most aftermarket coolers are made of aluminum tubing is economics.
I've read about copper leaching from oil cooler tubes and it happens on new vehicles under high temperatures but falls off greatly after a few oil changes and the copper in the cooler gets a layer of varnish on it and pacifies. Also mentions ZDDP in the oil can react with copper at high temperatures, but I'm thinking for power steering fluid which should stay below 200°F it there should be no problem ?
http://www.machinerylubrication.com/Read/646/copper-diesel-engine-oil
http://universallubes.com/assets/uploads/lubetalk/0207-2-CopperAnyone.pdf
