New safety spec for 2017 F1 cars...
by mcrn
05/28/16 03:35 PM
M1-101 after 10k on a 95 Sunfire 2.2 OHV pushrod
by slacktide_bitog
05/28/16 03:18 PM
Base Oil Content and Marketing
by MolaKule
05/28/16 03:08 PM
Best OTC fuel injector cleaner
by 007
05/28/16 03:06 PM
A brief BMW R1100RT story
by Finn
05/28/16 02:29 PM
2015 6.7L Powerstroke Fuel Filter Change
by 2015_PSD
05/28/16 12:51 PM
Caliper question
by supton
05/28/16 12:48 PM
Impressed with Yokohama Geolander A/T G015
by K20FA5
05/28/16 12:13 PM
Need a good tire pressure guage that read over 60
by MetalSlug
05/28/16 11:55 AM
Castrol 0w40 vs M1 0w40 FS ?
by Ndx
05/28/16 11:14 AM
what old Snapper parts to save
by edwardh1
05/28/16 10:56 AM
Interesting lunch hour
by Urshurak776
05/28/16 10:10 AM
mungchimp, troutwest66, AIRJAC3, bpete65, LEVY
58001 Registered Users
82 registered (87sammy, 2015_PSD, 2KBMW, 2K2AcuraTL, 340six, 04SE, 8 invisible), 1771 Guests and 321 Spiders online.
58001 Members
66 Forums
249529 Topics
#3015704 - 05/28/13 11:39 AM Aral 0W40 Super Tronic - Mercedes W204 C220CDI
Nikos_jd Offline
Loc: Greece
Here is my oil analysis from my Mercedes W204 C220CDI 2007model i using :
ARAL 0W40 SUPER TRONIC
ACEA C2, C3
API SN/ CF
MB 229.31/ 229.51
• BMW Longlife-04
• Fiat 9.55535 -S2
•Porsche A40
"Fully synthetic high performance engine oil for gasoline and diesel engines with and
without diesel particle filters. Based on ‘Aral Synthese Technologie’".
I send oil sample to blackstone one at 13.800km and 18.700km
Here is in 13.800Km on oil and 426,832km on my engine
Thanks for the extra information about this sample. Now that we know the type of
engine this is, we can compare it with our universal averages for the Mercedes 2.2L diesel engine, which are shown in
the far right column. Those indicate typical wear for this type of engine after ~5,200 km of oil use, so your longer oil run
explains why metals are higher. Everything's in good proportion, though, so we don't see any obvious issues. No
contaminants were found, and the TBN is good at 2.3, so the oil can run longer. Try 17,000 km next oil. Nice!
ALUMINUM =5 AVERAGES=3
CHROMIUM =2 AVERAGES=1
IRON =35 AVERAGES=21
LEAD =0 AVERAGES=6
TIN =0 AVERAGE=1
COPPER =5 AVERAGE=2
MOLYBDENUM =156 AVERAGE=42
NICKEL =0 AVERAGE=0
MANGANESE =0 AVERAGE=0
TITANIUM =0 AVERAGE=0
POTASSIUM =1 AVERAGE=7
BORON =54 AVERAGE=42
SILICON =5 AVERAGE=6
SODIUM =8 AVERAGE=7
CALCIUM =1752 AVERAGE=2933
MAGNESIUM =1346 AVERAGE=504
PHOSPHORUS =735 AVERAGE=1196
ZINC =890 AVERAGE=1433
BARIUM =0 AVERAGE=0
SUS VISCOSITY 210F=67.2 AVERAGE=64-76
CST VISCOSITY 100C=12.21 AVERAGE=11.3-14.8
FLASH POIONT F =455
FUEL =<0.5 AVERAGE=<2.0
WATER =0
TBN=2.3
The samle is leaked at transit a little and the paper with details is leaked,
The first comments with out deatails about km on engine and oil is that
This oil sample leaked in transit, so we didn't get any information about this sample. If you can supply us
with the engine type, oil type, kilometers on the oil and kilometers on the engine, we can get you a lot better
information. As it is, none of these wear levels look like a problem. The oil was also free of any harmful contamination
like fuel or anti-freeze and the TBN was still strong at 2.3, so there was some active additive left. 1.0 is a low TBN. Low
silicon shows good air filtration. All in all, a very nice first report for this engine.
I send the information for my engine and km on the oil and blackstone send me more expain comments
Sorry for bad English blush
Edited by Nikos_jd (05/28/13 11:44 AM)
#3015753 - 05/28/13 12:29 PM Re: Aral 0W40 Super Tronic - Mercedes W204 C220CDI [Re: Nikos_jd]
Quattro Pete Offline
Loc: Great Lakes
I'm no expert on diesel engines, but the report looks fine to me.
How many months was the oil in service?
It looks like you're accumulating kilometers very quickly. 427k km in 6 years... do you use it as a taxi or something?
'02 530i (Edge HM 10W-40)
'15 Q5 3.0T (Edge 5W-40)
#3015844 - 05/28/13 02:24 PM Re: Aral 0W40 Super Tronic - Mercedes W204 C220CDI [Re: Nikos_jd]
Nikos_jd Offline
Loc: Greece
Yes is taxi,about 5-6months
Later i will upload the other analysis for 18.700km on the oil..
Edited by Nikos_jd (05/28/13 02:26 PM)
#3015896 - 05/28/13 03:22 PM Re: Aral 0W40 Super Tronic - Mercedes W204 C220CDI [Re: Nikos_jd]
m37charlie Offline
Loc: Alaska
Surprisingly high Mg/Ca levels for a C3/229.51 oil. Aral does not list virgin TBN unfortunately.
Charlie
05 Unimog U500/Unicat camper/Delvac 1 SHC ACEA E4/E5
09 BMW X5 35d/Delvac1 LE 5W30
88 Toyota OJ50LV OM314 motor D1 SHC
52 Dodge M37/Hercules diesel
#3015943 - 05/28/13 04:00 PM Re: Aral 0W40 Super Tronic - Mercedes W204 C220CDI [Re: m37charlie]
Nikos_jd Offline
Loc: Greece
you are right wink i have been mistake
MAGNESIUM = 7 AVERAGE=216
#3016588 - 05/29/13 09:22 AM Re: Aral 0W40 Super Tronic - Mercedes W204 C220CDI [Re: Nikos_jd]
Nikos_jd Offline
Loc: Greece
Here is analysis after from 18.700km on the oil 445.532km on engine.
NIKOLAOS: A little more wear showed up in this sample, but that's okay given the longer oil run. Universal
averages show typical wear levels for this type of engine after about 16,300 km on the oil. In comparison,
your readings don't look bad at all and since the oil was still in good shape physically, we think a longer run
next time will be fine. The TBN was still 2.3, and that's a little unusual given the longer oil run. Maybe the
250 ml of make-up oil helped. In any case, that's still a strong reading and low insolubles show good oil
filtration, so try going 22,000 km next time
(Blackstone comments)
18.700km AVERAGES =16.500km
ALUMINUM =4 AVERAGES=5
CHROMIUM =3 AVERAGES=3
IRON =67 AVERAGES=51
LEAD =0 AVERAGES=0
TIN =1 AVERAGE=1
COPPER =8 AVERAGE=7
MOLYBDENUM =158 AVERAGE=157
NICKEL =0 AVERAGE=0
MANGANESE =1 AVERAGE=1
POTASSIUM =2 AVERAGE=2
BORON =56 AVERAGE=55
SILICON =6 AVERAGE=6
SODIUM =7 AVERAGE=8
CALCIUM =1695 AVERAGE=1724
MAGNESIUM =11 AVERAGE=9
PHOSPHORUS =710 AVERAGE=723
ZINC =876 AVERAGE=883
BARIUM =0 AVERAGE=0
SUS VISCOSITY 210F=74.3 AVERAGE=64-76
CST VISCOSITY 100C=14.08 AVERAGE=11.3-14.8
FLASH POIONT F =430
WATER =0
TBN=2.3
Edited by Nikos_jd (05/29/13 09:26 AM)
#3018490 - 05/31/13 08:55 AM Re: Aral 0W40 Super Tronic - Mercedes W204 C220CDI [Re: Nikos_jd]
Blasar Offline
Loc: Portugal
Nice numbers you have there for almost 19000km on the oil.
Normal wear of the engine parts, the TBN still looks strong enough and I didn´t even knew this brand of oil. blush
Regards.
Excuse my poor English.
#3378438 - 05/22/14 03:25 PM Re: Aral 0W40 Super Tronic - Mercedes W204 C220CDI [Re: Nikos_jd]
Nikos_jd Offline
Loc: Greece
How i can upload my oil analysis? to compare with other analysis,i use the Fuchs Titan Pro C3 5w30 the last time.
#3378448 - 05/22/14 03:35 PM Re: Aral 0W40 Super Tronic - Mercedes W204 C220CDI [Re: Nikos_jd]
Nikos_jd Offline
Loc: Greece
Edited by Nikos_jd (05/22/14 03:37 PM)
#3378602 - 05/22/14 06:26 PM Re: Aral 0W40 Super Tronic - Mercedes W204 C220CDI [Re: Nikos_jd]
yvon_la Offline
Loc: quebec canada
Wow that oil is uber!what diesel you use ?uls?or bio uls?any know if blackstone can analyse biodiesel?(5%,10%,15%,20%)to know the variable!
Truck driver
Nissan versa note s 2014 Mobil Delvac 1 LE 5W-30 supertech st-6607(edition 2016) castrol transynd
#3378891 - 05/23/14 01:27 AM Re: Aral 0W40 Super Tronic - Mercedes W204 C220CDI [Re: Nikos_jd]
Nikos_jd Offline
Loc: Greece
ULS Diesel but Contains 7- 10% biodiesel I think.
