It is a comment about the old days. There are better products for that today.
If you are changing your oil in a few days...why not try a "diesel oil" ..don't worry they work very very well in gas powered vehicals...Cheveron Delo...shell rottella T and Mobile Delvac 1300 have great cleaning power and the weight is usually 15w 40 ..being as it is thicker it may help to quit the noises...quote:
Originally posted by JR:
Is that a suggestion to use ATF or just a comment about the good old days? I am asking since I to have the same problem and question. I have a 1989 Ford Ranger withe the 2.9 litre V-6 and to have heavy lifter noise on start up. And lifter noise while running to. Warm and cooled. I have tried a veriety of weights and brands and still have the same amount of noise. I am planning on using some 5W-20 I have on the self in it. I will be changing the oil in the next coupe of days. I was wondering what I could use that is availible at any store. I also should add that the engine has only 130K miles on it. It doesn't use any or leak any. I have to back on out of here for now. Thanks in advance for the support.
I don't think that quote applies to some of us who must drive older vehicles. For example, just 3 posts above yours, someone writesquote:
you shouldnt rely on a additive to fix a mechanical problem
That person could easily spend more than the 17 year old vehicle is worth or even will be worth after the expense of having the lifters replaced. If he can get quieter lifters using ARX, another brand of oil, or other additives for a few dollars, I say go ahead. Many others claim these changes helped or even cured the noise problem.quote:
Yeah, um, is their cleaning power that outstanding that you should only leave them in a few days? I've run HDEO for 2 OCI's and haven't noticed THAT much difference.quote:
