I agree but unless you are tracking it mpg, compression results, fuel loads etc you will see nothing. Plus LC20 can clean ring packs too; no switching to dino oil either (which I dislike). I just personally feel most “think” it will not hurt it to add ARX; which you could be right. But as someone on this forum said most would say you should add it to a new car too. I would verify you need to do anything as I noted before. Don’t just start adding fluid cleaners to your oil because you think you need it. If you do not know before what you have….
Also everyone is ring pack happy now-a-days when several times it (cleaners) are not needed. Based on his pix on the other thread, no sludge just varnish; typical of toyo engines along with others.
As I posted before about my auto “I am getting over 25 mpg non-highway, based on 02 voltages, calc loads, oil tests, fuel trims, it is running perfect.” I saved my $24 and bought some LC to try. Going to test next month to see the Nox, OXD and TBN levels; since I know the last 3 years of testing. Main reason was for acid and TBN control. See if it is worth it and outside of that, nothing else is needed.
