Weapon Shield
by Ws6
02/11/16 12:33 AM
Amsoil Euro 5W-40 92Benz 190E 2.3L 8V 3889 miles
by IllinoisSparky
02/10/16 09:11 PM
Which oil?
by SEMI_287
02/10/16 09:05 PM
Fluid change on my 2015 Accord
by dan_erickson
02/10/16 08:56 PM
Upgrading brakes
by ram_man
02/10/16 08:49 PM
Rear end sounds like an airplane
by mclasser
02/10/16 07:49 PM
GDI engine's and motor oils
by gabriel9766
02/10/16 07:42 PM
Old toyota Need shocks?
by ceast
02/10/16 07:27 PM
How to do a clean install
by Oldmoparguy1
02/10/16 07:21 PM
Troy Bilt Pony
by OSUFan86
02/10/16 06:43 PM
$1.33 for a GALLON of 87!
by Vern_in_IL
02/10/16 06:30 PM
Eating out, beware you all
by CourierDriver
02/10/16 06:13 PM
BlueKelah, threeeightteen, TOADchunks, Longo9596, Roadrunner77z
56889 Registered Users
49 registered (akela, Astro14, bdcardinal, Ben Boyle, 87sammy, bbhero, 5 invisible), 756 Guests and 191 Spiders online.
56889 Members
66 Forums
244531 Topics
Page 1 of 2 1 2 >
#3009963 - 05/22/13 03:39 PM 1998 Jeep Cherokee (XJ) Oil Suggestions
George1992 Offline
Loc: Chicago Illinois
Hey guys!
Thanks again for the help on my '98 Ram thread, now I have another question.
I have a 1998 Jeep Cherokee- 4x4
4.0L Automatic - 143,000.
Driven about 50-120 miles a day, about 70/30 Highway City.
Bought the Jeep at 130k, replaced the floors, and did some small engine /suspension work. It seemed to be pretty neglected, and had some decent lifter noise on startup, went away after my first oil change with it.
Been running Mobil 1 10-30 High Mileage with a MOPAR filter for about 4-5k OCI's just because I didn't know the history of the engine.
Does not burn any oil, maybe get a drip or two from the rear main not enough to be noticeable.
Looking for a suggestion/opinion on a lower viscosity oil? Different filter? Would like to stay synthetic, price isn't an issue.
Thanks again fellas!
Here's a picture of it.
1998 Dodge Ram - 360/Auto 4x4 - 152k (Mobil 1 10W-30/Mopar MO-90)
1998 Jeep Cherokee (XJ) - 4.0/Auto - 142k (Mobil 1 HM 10W-30/ Mopar MO-90)
#3009973 - 05/22/13 03:48 PM Re: 1998 Jeep Cherokee (XJ) Oil Suggestions [Re: George1992]
dave1251 Offline
Loc: Maricopa, AZ
If what you are using is working I would not change a thing.
don't use.
#3009977 - 05/22/13 03:51 PM Re: 1998 Jeep Cherokee (XJ) Oil Suggestions [Re: George1992]
Realtech214 Offline
Loc: Florida
A buddy of mine has the same jeep and he uses Mobil Super 5000. His engine runs very smooth and quiet with that oil. It also has 260K miles
2015 Silverado Crew Cab 5.3 LT
2001 Suburban LT
- I NEVER THOUGHT I WOULD LIKE OIL SO MUCH -
#3009999 - 05/22/13 04:03 PM Re: 1998 Jeep Cherokee (XJ) Oil Suggestions [Re: George1992]
KCJeep Offline
Loc: Mahzurrah!
Saweeett looking XJ bud! thumbsup
approved
These engines are spec'd for 10w30 and for good reason, so stay with that over a lower viscosity such as 5w30. It's not so much the operating characteristics as shear is the reason, the 4.0 does not like anything less than a good 30 grade and when the 5w30 inevitably shears it is too thin for optimum protection in the venerable 4.0.
Mobil 1 has consistently produced up to 4 times more iron in UOA's in this engine than just about any other oil, but the best Mobil 1 UOA's have been with the HM version you are using. So I'd suggest you find a new synthetic 10w30, but if you're stuck on Mobil stay with the High Mileage.
2004 Jeep Grand 4.0 @ 130k Pennzoil HM 5w30 w/ 1 qt 10w40
Fram TG8A
KIA Sedona 55k, Chevy Lumina 182k, Chrysler Sebring 183k, Chrysler Concorde 111k
#3010004 - 05/22/13 04:10 PM Re: 1998 Jeep Cherokee (XJ) Oil Suggestions [Re: George1992]
Miller88 Offline
Loc: Onondaga County
That XJ is worn out and beat up - you should just donate it to me wink haha - Nice looking Cherokee!
The 4.0s aren't picky about oil. Any 5w-30, 10w-30 or 5/10w-40 will work perfect.
I'm a fan of the larger Fl-1A ford filter in the Cherokee 4.0.
I have been running RT6 5w-40 in mine, last oil change was on a 5w-20/5w-30 blend .... I'm going back to RT6 as I'm due for an oil change.
Edited by Miller88 (05/22/13 04:10 PM)
I run the 10w30 becuase 0w20 makes my CVT shift funny
#3010010 - 05/22/13 04:16 PM Re: 1998 Jeep Cherokee (XJ) Oil Suggestions [Re: Miller88]
KCJeep Offline
Loc: Mahzurrah!
I did a run of 5w20/5w30 blend in mine also, then did a UOA and it was NOT good. frown Too thin IMO. Stay with that T6!
Fram TG8A
#3010015 - 05/22/13 04:22 PM Re: 1998 Jeep Cherokee (XJ) Oil Suggestions [Re: George1992]
George1992 Offline
Interesting guys thanks,
Now maybe im nuts but I had an FL1A in my garage from an '86 Crown Vic and could not get it to thread on! Am i just an idiot??
That T6 has me interested 5W-40? Will I have to be worried about shearing issues as mentioned by KCJeep? or is that solved by not being a 5W-30 but a 40?
Thanks!
#3010018 - 05/22/13 04:24 PM Re: 1998 Jeep Cherokee (XJ) Oil Suggestions [Re: George1992]
KCJeep Offline
Loc: Mahzurrah!
Bingo! It will still likely shear, but down to a "thick 30" at most. A 5w30 can shear down into 20 grade range, not a good match for the 4.0. The 4.0 needs at least a solid 30 grade, but will tolerate much thicker oils without apparent issue.
My buddy is running T6 in his XJ as well and really likes it.
Fram TG8A
#3010344 - 05/22/13 09:37 PM Re: 1998 Jeep Cherokee (XJ) Oil Suggestions [Re: George1992]
George1992 Offline
I think T6 it shall be for the next OC.
Going to do a UOA for this current M1 run (it'll be 6k) just for the heck of it, then the same for the next with T6.
Now provided nothing major shows up in this UOA, 6k with the T6 and a Mopar filter should be ok correct?
Thanks!
George
#3010356 - 05/22/13 09:51 PM Re: 1998 Jeep Cherokee (XJ) Oil Suggestions [Re: George1992]
KCJeep Offline
Loc: Mahzurrah!
Yep. The T6 may be good for closer to 10k but I wouldn't push it that far with a UOA.
A Motorcraft is identical to a Mopar except for the paint and the price. Both made by Purolator. You can't get the "spec" size in a Motorcraft any more, but many guys run the original larger size for that engine which is the very common Motorcraft FL-1A.
Nothing wrong with running the M0-090 either, it does say "Jeep" on it! smile
Fram TG8A
#3010397 - 05/22/13 10:36 PM Re: 1998 Jeep Cherokee (XJ) Oil Suggestions [Re: KCJeep]
Troy_Hale Offline
Loc: Cincinnati, Ohio
I look forward to your results. I'm still on the bulk Valvoline 10W-30 that was in the car when I bought it, and am having trouble picking what I'll use next.
You mention the car was neglected, but you must have done a great spit shine job, Jeep looks great!
2006 Mini Cooper S - 74K - BMW 5W-30 Synth
1994 Jeep Cherokee Country - 93K - Shell Rotella T5 10W-30
1999 Mazda Miata MX-5 - 98k - unknown lube
#3010423 - 05/22/13 10:58 PM Re: 1998 Jeep Cherokee (XJ) Oil Suggestions [Re: George1992]
AmishFury Offline
Loc: Indiana, US
over on jeepforum the most popular oils for the 4.0 are QS Defy and Rotella T5 neither is a full syn but both common recommendations
#3010744 - 05/23/13 09:24 AM Re: 1998 Jeep Cherokee (XJ) Oil Suggestions [Re: George1992]
jeepman3071 Offline
Loc: Storrs, Connecticut
Nice XJ!
Both me and KCJeep have found that our 4.0s run quietest with Pennzoil Yellow Bottle due to the high moly content. I think Pennzoil Yellow bottle 10w30 would be perfect for the 5,000 interval with the Mopar filter, and you'd save a bit more over the synthetic.
I ran Mobil 1 HM 10w30 in my Jeep, and it burned a whole quart in 3,000 miles. It had never consumed oil before that, and once switching to another oil the consumption stopped.
I think for the price, you can't go wrong with Pennzoil Yellow bottle 10w30 or the Rotella T5 10w30. Both are a great oil for the money. thumbsup
2000 Jeep Cherokee Sport 4.0L (161k) - PYB 5w30, Napa Gold 1516, Magnefine trans filter
#3010843 - 05/23/13 10:56 AM Re: 1998 Jeep Cherokee (XJ) Oil Suggestions [Re: George1992]
MrRPM Offline
Loc: Michigan
My jeep had a slight rear main seal leak the 4.0s are known for, nothing left on the ground in the morning but if you touched the area your hand would be wet with oil. After 3 OCIs (early on my 3rd now) of Quaker State DEFY mileage starting at 84k and now at 91k, the Rear main seal is dry to the touch. I haven't run a UOA yet with defy but I wanted to do a few short OCIs with the defy first anyway.
so Far I'm very happy, runs quieter then the fill of m1 0w-40 I used before but really its hard to compare that kind of thing anyway.
Edited by MrRPM (05/23/13 10:57 AM)
2001 Jeep Wrangler 4.0L, 5qts Quaker State DEFY 10w-30/1qt kendall GT-1 20w-50, FRAM XG8A (ultra)
#3010913 - 05/23/13 11:56 AM Re: 1998 Jeep Cherokee (XJ) Oil Suggestions [Re: George1992]
KCJeep Offline
Loc: Mahzurrah!
I've run Defy once so far and liked it, Jarlaxle did a Jeep 4.0 UOA on Defy as well and it looked really good.
Fram TG8A
Page 1 of 2 1 2 >
