2009 Corvette Coupe, LS3 engine, A6 trans.
Bought new, now at almost 60k miles
Always use Mobil1 5W-30, GM filter, changed at 30%-50% Life Remaining (5k-9k miles)
Just as a hobby, I send a sample to Blackstone Labs from every oil change. Lead level is typically 7-9, and other metals are normal.
At 37,096 miles/7,711 on oil (Sept 2011), lead spiked up to 13. Copper was normal, Tin went from 0 to 5. Blackstone said it was probably a particle streak in a bearing, don't worry about it. Sure enough, the next two changes with about 7k miles on each, showed lead dropped back to 8 which is normal and tin was 0.
At 59,458 miles/8,699 on oil (May 2013), lead spiked up to 17.
All other metals normal, copper actually dropped a little and Tin was 1. Blackstone says this is still not a big deal, but they are wondering why it's happening. So am I.
If it's a particle streak, what could be causing it? Could changing spark plugs or cleaning MAF dislodge something that sticks in a bearing?
I don't track the car, though I often corner it hard in the twisties. But on street tires (PS2 runflats) and keeping the oil 1/4 - 1/2 qt above the Full mark (recommended 1 qt above for real racing), oil starvation seems unlikely.
Any comments on the significance of these numbers, or what do do differently?
