Looking for help in diagnosing a possible transmission problem.
2000 Accord 4 cylinder 182xxx miles, automatic. Got it used with 66xxx miles.
Symptoms: rough 1-2, 2-3 and 3-4 shifts, the transmission doesn’t seem to downshift to 1 when coming to a full stop. I feel a clunk when coming to a full stop at the moment it stops completely. It seems to happen only after the car is warmed up but once it happens it doesn’t go away until it’s parked for a few hours and this process repeats itself, . Shifts okay when started cold for about 15 to 25 mins then gradually the rough shifting would come back. I got a CEL with a blinking D4 light, P1750 and P0700 and another code that’s emissions related EVAP, I believe. This pointed to the clutch pressure solenoids. Replaced the clutch pressure solenoid/gasket and these three metals pin things in the solenoid. CEL is gone and have not come back. But the rough shifting came back about a week or two later – although still no CELs. I next replaced the shift lock solenoids and this did nothing, although the two old screens inside doesn’t look very good (kind of clogged up). In between this have done a couple of drains and refills with Honda ATF Z1 fluids. Actually the first thing I did when this first happened was to drain and fill the fluid with HONDA ATF, always used Honda ATF. Lastly, as a last resort, I replaced the two shift solenoids, B&C, and nothing has changed.
When the bad shifting happens and I pull over and turn off the engine and restart after a few mins it seems to shift better although I need to test this a couple of more times to confirm.
Anything else I should try or is this definitely the transmission that’s the problem?
Appreciate any assistance.
