Originally Posted By: buster
JAG said it well here. I personally hold that view, others may not and that's fine.
Quote:
Unfortunately, with synergy and antagonism being a reality between different additives and also between base oils and additives, by mixing you are more likely to create antagonism than synergy by mixing very different motor oils.
With synergy, 1+1 may equal 3.
With antagonism, 1+1 may equal 0.7.
If you want a better oil, use a better oil without mixing it with anything. If you want to use up old stock, it is very reasonable from a cost perspective to mix different oils.
JAG never said that in this thread so why are you quoting him?
We all know that you're not into mixing oils which is fine, but what does that have to do with this thread? Nothing.
