Hi,
I use Multifunctional tractor oil STOU 10W30 CF-4/SG and GL-4 for my tractors with 1400ppm of Zn. My Honda CB500 needs 10w30 SG.
The STOU oils are designed to work with wet brakes and wet cluctch. Are they containing the same kind of friction modifiers as JASO oils ?
So, should I use STOU oils with motorcycle wet clutch ?
Thanks
Thanks
