Just because someone trying to blow smoke on you doesn't necessary mean that they are telling da truth.
Mola is right about boric acid and frankly, who would wanna throw some boric acid into their motor oil to begin with (if there's ever the intention of doing so).
Modern motor oils are, IMHO, leapyears away from what we used to use a decade ago, or even 6 yrs ago to be honest with you. I wouldn't wanna upset the balance of the chemical additives/packages within and will constantly question the motives/thoughts of adding something "foreign" into the oil mix.
technological advancements in electronic computer management control (EFI, E-DI, etc.) has reached a never attainable level of fuel delivery precision and control to the point where because of a more complete burn, a well-controlled cold start fuel/air mixture delivery, etc. lubricating oil film washoff(dilution) by raw, unburned gasoline problem is almost gone (recall caburettor?). This is also an indirect contributing factor to the longevity of motor oil in modern engine due to lack of washoffs(dilution) and contamination due to incomplete combustion process, and less crankcase contamination...
