Jury Duty
by dishdude
08/29/16 12:42 AM
Mercon LV or MaxLife
by buck91
08/28/16 11:46 PM
VW Electric Plans
by Y_K
08/28/16 10:49 PM
Oil Recommendation for Nissan 3.5 V6 113,000 miles
by BlueSmoke16
08/28/16 10:10 PM
Sticky Ear Question - Speak Up!
by Ducked
08/28/16 10:07 PM
House hunting follies
by Jarlaxle
08/28/16 09:36 PM
Goodbye, Stubby
by Inspecktor
08/28/16 09:35 PM
Undercarriage
by jay929
08/28/16 09:31 PM
$1200 Cabela's Gift Card For Sale- Louisville, KY
by FirstNissan
08/28/16 08:37 PM
Motor oil recommendations, '04 Toyota Sequoia
by ShadowSix
08/28/16 08:21 PM
Quick Question About Car Battery Quality And Price
by crazyoildude
08/28/16 07:44 PM
Shelf Life of Gas Stabilizer.
by George7941
08/28/16 07:34 PM
gioburk, turrican, GGilbert, leje0306, DLL
58951 Registered Users
30 registered (bbhero, DemoFly, DeafBrad, c502cid, asiancivicmaniac, 3 invisible), 754 Guests and 12 Spiders online.
58951 Members
66 Forums
253707 Topics
Page 1 of 2 1 2 >
#3004412 - 05/16/13 08:50 PM Results Are In On the First Batch Of Diesel Engine
2004tdigls Offline
Loc: maple ridge, bc
http://www.pqiamerica.com/May%202013/consolidatedhdeo.html
interesting results, walmart supertech looks ok
just one question, Why the differences in the calcium levels
#3004420 - 05/16/13 08:53 PM Re: Results Are In On the First Batch Of Diesel Engine [Re: 2004tdigls]
147_Grain Offline
Loc: USA
Chevron Delo 400 LE surprised me a bit with 679 ppm of boron.
#3004426 - 05/16/13 08:58 PM Re: Results Are In On the First Batch Of Diesel Engine [Re: 2004tdigls]
cat843 Offline
Loc: East Coast, USA
This was posted a week or two ago.
Cat-Man-843
#3004435 - 05/16/13 09:04 PM Re: Results Are In On the First Batch Of Diesel Engine [Re: cat843]
2004tdigls Offline
sorry
did not know this
#3004498 - 05/16/13 09:53 PM Re: Results Are In On the First Batch Of Diesel Engine [Re: 2004tdigls]
motor_oil_madman Offline
Loc: Houston, Texas
The reason why I use delo. The best additive package of them all.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
#3004569 - 05/16/13 11:46 PM Re: Results Are In On the First Batch Of Diesel Engine [Re: 2004tdigls]
Swissdieselfan Offline
Loc: Romanshorn, Switzerland
I really can't understand what is the difference between an HDEO and a normal diesel oil?? Delo is the only one that looks like my idea of an HDEO, although it's a pity they did not include the Castrol ones, although they only seem to be available in bulk, even in the EU, apart from some truck stops.
#3004796 - 05/17/13 08:50 AM Re: Results Are In On the First Batch Of Diesel Engine [Re: 2004tdigls]
miniac007 Offline
Loc: Sweden
The difference is less important now with CJ-4 and low ash oils and low sulfur diesel... But if you look at CI-4/CF-4, you will see more difference.
You have the castrol VOA here: http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=903900
It is just a expensive price (in europe, dunno in USA) on a low average pack with no bore, just zinc...
Edited by miniac007 (05/17/13 08:52 AM)
#3005239 - 05/17/13 05:10 PM Re: Results Are In On the First Batch Of Diesel Engine [Re: Swissdieselfan]
Garak Offline
Loc: Regina, Saskatchewan, Canada
Technically, a diesel engine oil wouldn't be dual rated. What we call HDEOs tend to be dual rated.
Plain, simple Garak.
2008 Infiniti G37 coupe - Mobil Delvac 1 ESP 5w-40, Wix 51358
1984 F-150 4.9L six - Quaker State GB 10w-30, Wix 51515
#3005632 - 05/18/13 02:39 AM Re: Results Are In On the First Batch Of Diesel Engine [Re: Garak]
fpracha Offline
Loc: MA
so what really makes a diesel engine oil capable of being spec'd as a dual-rated oil ?
#3005785 - 05/18/13 09:02 AM Re: Results Are In On the First Batch Of Diesel Engine [Re: fpracha]
Garak Offline
Not being a formulator, I'm not sure I can answer that without being terribly circular. wink
I would say that would include being able to meet the SM (or whatever S spec is met). Of course, that doesn't really answer anything. I think the main contrasts you would see would be if you looked at something like a two-stroke diesel lube, whose elemental analyses are very, very different from what you'd see in a normal HDEO or PCMO. The two-stroke diesel oils whose analyses I've read have very low zinc content, if I remember correctly.
Obviously, too, in a dual rated oil, the specifications are shown as CJ-4/SM, and certain limitations (i.e. phosphorous) are handled differently than a normal SM or higher, even in a 30 grade. A 10w-30 CJ-4/SM can have more phosphorous content than, say, even a 10w-30 SM, even if the latter weren't GF-4. How much higher the limits are, I'm not sure, but if you put me on the spot, I'd suggest a couple hundred ppm.
#3007247 - 05/20/13 02:53 AM Re: Results Are In On the First Batch Of Diesel Engine [Re: Garak]
fpracha Offline
Loc: MA
Ok thanks!
what about CJ-4 only rated diesel oils... would they not contain high zinc content ?
and in this case, even if SM is not mentioned in its specs, would this CJ-4 rated oil not suffice the base oil requirements of almost any gasoline engine (with the exception of, perhaps, only a few most modern hybrid engines) ?
#3007319 - 05/20/13 06:35 AM Re: Results Are In On the First Batch Of Diesel Engine [Re: fpracha]
Garak Offline
A CJ-4 oil should be much the same as a CJ-4/SM. I haven't seen many examples that are CJ-4 only. The U.S. Motorcraft 15w-40 and the Mobil Delvac Elite 10w-30 synthetic blend are the only two that come to mind as CJ-4 only. The former used to have the gasoline rating, and the latter is new in North America. The real concerns with respect to gasoline engines would be the phosphorous content and the viscosity. Both numbers are obviously too high to get a GF-5 rating (or the older GF-4 rating), which is usually called for in most manuals.
So, I don't know what I'd do if I were confronted with those two oils. I'm sure they'd be "fine," particularly in an older engine, but I would be curious as to why they didn't have an SM rating as well. I could see Motorcraft's stance as wanting to make extra sure that people don't use their 15w-40 in a gasoline engine under warranty. I'm not sure what XOM's motivation is, since they do make a dual rated 10w-30 already, and both of their 15w-40 products are dual rated (along with many of the others).
I'd worry most about the two-stroke diesel oil. But,
#3016482 - 05/29/13 06:55 AM Re: Results Are In On the First Batch Of Diesel Engine [Re: 2004tdigls]
pbm Offline
Loc: New York
The Autozone near me has the latest Mobil 1 5w40 (CJ-4/CI-4/SN) on clearance for $3 a quart.
I picked up a couple of quarts but I don't know where I'll use it. Does it have any value as a PCMO?
What would a 50/50 mix of this oil with Mobil 1 0w20 yield?
#3016858 - 05/29/13 03:11 PM Re: Results Are In On the First Batch Of Diesel Engine [Re: Garak]
bullwinkle Offline
Loc: Cincinnati, OH, USA
...the problem with the 2-stroke diesel/CF-2 spec is that it is now an obsolete spec, which means API doesn't license (or test) those oils anymore (?)
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 15 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(CQ Blue)
#3017289 - 05/29/13 10:14 PM Re: Results Are In On the First Batch Of Diesel Engine [Re: 2004tdigls]
DB_Cooper Offline
Loc: Ga
The Delo LE 15w40 looks like it has the strongest additive package of all the 15w40 HDEO sampled.
Why is the TBN number the lowest of all the 15w40s?
#3017414 - 05/30/13 05:36 AM Re: Results Are In On the First Batch Of Diesel Engine [Re: bullwinkle]
Garak Offline
That might be true, but one still could come across some inappropriate lubes. It might take some doing, though. After all, any 15w-40 HDEO you or I find on the shelves is very likely to be dual rated. I'm still wondering why Motorcraft and XOM have those two outliers with respect to gasoline ratings, though.
@DB_Cooper: That TBN might seem a bit low, particularly compared to what we're used to with HDEOs. It's actually not that out of line with a number of products out there, particularly some of the newer HDEOs. It seems that unless a newer HDEO meets an ACEA specification calling for a higher TBN, it's likely going to be in the 7 range. That's really not a problem, though, with ULSD. The guys pushing the OCIs in the diesels will likely be using an ACEA rated synthetic that will have a higher TBN.
#3018084 - 05/30/13 06:56 PM Re: Results Are In On the First Batch Of Diesel Engine [Re: Garak]
DB_Cooper Offline
Loc: Ga
Thanks Garak..Delo looks like very stout stuff. A UOA at 5k would be interesting on a 1.8 VW engine I built recently.
#3084461 - 08/03/13 11:11 AM Re: Results Are In On the First Batch Of Diesel Engine [Re: 2004tdigls]
Brons2 Offline
Loc: Austin, Texas
Delo ftw if you're using it in a classic gasser with high valve spring pressure.
Delvac ftw for longer oci in diesel.
Mine: 2007 Kia Rondo LX 2.4 I4 5 pass, M1 HM 10w30, OEM filter
Hers: 2010 Rav4 Sport 2.5 I4, M1EP 0w20, OEM filter
Page 1 of 2 1 2 >
