gr8gatzby,
Lube Control is not a one time additive, LC is more of a additive you need to continuously use because the engine will dirty itself from use,
a internal combustion engine continuously gets dirty from the breakdown of oil, the blowby debris pumped into the oil, etc.,
to keep the engine clean and help the lubricant do its job LC needs to be added on a regular basis, hope this helps.
