A friend had a code on his vehicle P0605 I believe it said ecm read error. No other codes. It's running fine but will he need to replace the ecu and if so is it a simple plug and play or will it need to be programmed? Can you just find a similar ecu or does it have to be exact with year, make, model, options?
It's a 2006 F150 Stx
4wd
4.6 v8
Auto transmission
No anti theft on the vehicle.
4wd
4.6 v8
Auto transmission
