Originally Posted By: mattd
That engine needs a full tear down and inspection. Its been run with 0 oil pressure for far too long.
By throwing a set of rod bearings at it you are wasting your $ IMO.
You'll never be able to clean all the metal out, and will just ruin your new set of bearings.
That definitely sounds like spun bearing...
What does the oil look like?? Drain it in a bucket and look for metal shavings.
Believe it or not, I did change the oil today. Put in a quart of the old, 2 quarts 20W-50, and some Lucas. No metal shavings.
I am actively seeking someone that can help me do these things. It sounds like checking the rods, doing the bearings.. I believe there to be SOME oil pressure,... so the engine is basically running off of what was in the cylinder walls? Maybe that is why it is stalling more?
I let it cool down a long time today, I started her up to drive it back/forth about 30 seconds, sounds like it was building compression.
Something about "rod bearing" don't add up, other things do...
I wish I could find someone to try these "on the cheap" fixes. I believe they will do the job, and yes I will clean out the filter frequently. It sounds and runs far too well to be scrapped.
I have also stopped starting it up, today was its last day of running/moving.. I took the videos you see, and I have the spare engine in the back.
