I've decided that the Jeep needs some summer tires for this year. It burns through all-terrains at an alarming rate on pavement (25 - 30k miles to hit the wear bars). Then again, I do drive it pretty hard, which doesn't help. I'm thinking this summer I'll pick up another set of wheels (17x8) and put some summers on them. They probably won't last any longer, but at least they'll be stickier in return, and then I can save the A/Ts for when I need them.
I'm torn between a few tire choices:
General Grabber UHP in either 255/60R17 or 275/55R17 ($139 each)
Goodyear Eagle F1 Asymmetric in 255/60R17 ($226 each, $80 rebate on the set)
Michelin Latitude Diamaris in 275/55R17 ($179 each, closeout so I won't be able to get another set in the future)
What do you guys think would be best between those tires? The 275s will be fairly pinched on the wheels, but not any worse than my current A/Ts (255/65 on stock 16x7).
I'm tending towards the Michelins as they're said to be very sticky and people report them having stiff sidewalls (and they're middle of the road price-wise), so a 275 on an 8" wheel would be less of an issue than with the Grabbers. The Goodyears look good as well, but they're the most expensive of the bunch by a good margin. The Grabbers have a significantly higher treadwear rating (360 A A, compared to 220 AA A for the Michelins and 240 AA A for the Goodyears), so I'm thinking they're probably not as sticky, although they are fairly cheap.
The 275s will also be a very tight fit under the Jeep, but from my measurements, it should work (it'll just be very tight to the fenders).
