Ok, need some positive thoughts here!
2000 S80 received a NEW from Volvo transmission at 170K. Car now has 222K and has a code for a stuck 1 to 2 solenoid.
Yet to touch it, I am on the road ,daughter gave me code AAA towing read her.
Thoughts: clear code, see if it goes away , look for a bad ground or a bad transmission electrical connector?
I am not into dropping the engine to pull the trans side cover /pan to replace solenoid! Car is in the home stretch of life! Its a shame, 1 owner, always had 3 K oil changes!
Any other simple things I can look at? Thank you
