cstoremotoroil.com
by AirgunSavant
08/27/16 09:37 AM
What's good/bad about a 2006 Mazda 5?
by 55Test
08/27/16 09:30 AM
My 1st air impact - go with 3/8" or 1/2" drive ?
by Cressida
08/27/16 08:55 AM
Silly me
by jay929
08/27/16 08:41 AM
15K oil & filter
by marine65
08/27/16 08:36 AM
Battery or starter
by Dallas69
08/27/16 07:56 AM
Napa Syn 15w50 to replace BradPenn 20w50 in 454bbc
by FlyNavyP3
08/27/16 07:51 AM
Real Main Seal Leak ? ? ?
by larryinnewyork
08/27/16 07:35 AM
Gov't wants to lower speed limits for trucks
by JetStar
08/27/16 07:11 AM
GM 55560202 longlife cut open - 10782km
by turboseize
08/27/16 04:54 AM
Coolant Question.
by Farmer
08/27/16 04:20 AM
Stocking up for the Eco
by buck91
08/27/16 12:25 AM
therhett17, glldprimr, krankshaft, Tony_Rhed, greasemonkey1
58935 Registered Users
80 registered (55Test, 4WD, 2015_PSD, a1mfw, 2004tdigls, A310, 8 invisible), 1658 Guests and 36 Spiders online.
58935 Members
66 Forums
253619 Topics
Page 1 of 2 1 2 >
#2993198 - 05/04/13 07:10 PM Most common socket size and screws on 2007 MDX
cadfaeltex Offline
Loc: KS
Wanting to fill out out my tool kit. What are the most common socket sizes and screw heads used in my wife's 2007 Acura MDX? Any other tools you can suggest?
Bonus Question: Same question for my 1994 Jaguar XJS 4.0L. A little obscure but I already asked on the Jag sites wink
#2993204 - 05/04/13 07:18 PM Re: Most common socket size and screws on 2007 MDX [Re: cadfaeltex]
dishdude Offline
Loc: Phoenix
You can probably take the entire Acura apart with a 10mm socket.
#2993212 - 05/04/13 07:25 PM Re: Most common socket size and screws on 2007 MDX [Re: dishdude]
rjundi Offline
Loc: USA
As a 3x Honda owner now on Acura MDX 07 also so true. I own a small set of tools but 10mm seems to be heavily used.
#2993217 - 05/04/13 07:32 PM Re: Most common socket size and screws on 2007 MDX [Re: cadfaeltex]
Chris142 Online   content
Loc: apple valley, ca
8,10,12,14,17,19mm
02 Wrangler Chevron 10w30
87 F250 napa 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#2993219 - 05/04/13 07:35 PM Re: Most common socket size and screws on 2007 MDX [Re: cadfaeltex]
NHGUY Offline
Loc: USA
13mm has to be popular.Thats usually the head size of an 8mm bolt.
#2993232 - 05/04/13 07:50 PM Re: Most common socket size and screws on 2007 MDX [Re: cadfaeltex]
Quest Offline
Loc: beaver land EH?
of all the metric sockets/wrenches I'ved use in servicing imported automobiles, never in my life would I have to use 13mm for once.
the most bizarre thing is, when you buy wrench/socket set, many a times the cheeper ones only come with 13mm, but seldom with 14 mm (which gets used regularly in servicing Japanese automobiles)....
my take 10mm, 12mm, 14mm, 15mm, 17mm, 19mm.
8mm mostly on brake bleeding nipples. And sometimes, you may need 21mm or 22mm.
Q.
"Internet discussion boards act as echo chambers for conspiracy dittoheads" A.Allen
#2993251 - 05/04/13 08:00 PM Re: Most common socket size and screws on 2007 MDX [Re: Chris142]
The Critic Offline
Loc: Walnut Creek, CA
Originally Posted By: Chris142
8,10,12,14,17,19mm
+1
I think some of the newest Honda SUVs now use 22mm for the lug nuts.
11 Prius - 133k - M1 EP 0w20/OE
07 Accord 2.4 - 112k - M1 5w20/Fram Ultra Filter
10 Altima 3.5 - 35k - M1 EP 5w30/FU
92 Previa - 160k - Chevron 5w30/Wix
#2993281 - 05/04/13 08:30 PM Re: Most common socket size and screws on 2007 MDX [Re: cadfaeltex]
eljefino Offline
Loc: ME
22mm is very close to 7/8, a common lug nut size.
Bolt heads are not so closely associated with the threaded part's diameters. Seems like they like to cheat from the standard and make them 1 or 2mm smaller for some reason, presumably production related but possibly just lightening/ cheapening.
For a while I suffered without a 15mm impact socket, my set went 14 to 16. Some wrench sets skip 18mm for some reason as well. If you can wait for after Father's Day there'll be great clearance sets at Depot/Lowes.
#2993320 - 05/04/13 09:17 PM Re: Most common socket size and screws on 2007 MDX [Re: cadfaeltex]
crazyoildude Offline
Loc: New Jersey
10mm
Will Not Use Oil Filters With Those Tiny Restrictive Looking Louvers! Also Not A Fan Of Oil Jugs That Don't Have A Security Inner Seal..
#2993677 - 05/05/13 10:26 AM Re: Most common socket size and screws on 2007 MDX [Re: Quest]
JC1 Offline
Loc: Oshawa, Ontario Canada
Q.
+1 for these. If you are just doing basic maintenance 10mm will cover the small stuff. Anything with Brake work or work on the engine will be larger sized fasteners. For Japanese cars its best to have 8 mm sockets all the way up to 24 mm if you are doing timing belts etc. I've also invested in a set of gear wrenches which are a necessity when doing work on the engine with very minimal clearance.
Regards, JC.
2015 Grand Caravan SXT Plus 5w-20 PPPP/Wix Filter
1997 Honda Civic CX 5w-30 Mobil 5000/Pureone Filter
#2993681 - 05/05/13 10:30 AM Re: Most common socket size and screws on 2007 MDX [Re: cadfaeltex]
stephen9666 Offline
Loc: USA
Just get a complete set from 8-19 and you'll be covered for almost any vehicle. You can add the larger sizes if/when you need them.
The Craftsman mechanic's tool sets are still USA made and are by far the best bargain in sockets. Many of them will include the larger sizes, too.
#2994280 - 05/06/13 01:37 AM Re: Most common socket size and screws on 2007 MDX [Re: cadfaeltex]
ajchien Offline
Loc: los angeles
Bolts:
5.5,8,10,12,14,17,19 on the stock honda/acura car.
13 and 18 are seen on accessories ... Like side steps and running boards etc.
Screws:
Phillips #2 and #3
JIS #2 and #3
Edited by ajchien (05/06/13 01:39 AM)
#2994291 - 05/06/13 03:03 AM Re: Most common socket size and screws on 2007 MDX [Re: cadfaeltex]
cadfaeltex Offline
Loc: KS
AJChien, you bring up something I thought was not there -- JIS screws. So are they still used? I had been led to believe they had been phased out in the 80's or 90's.
#2994595 - 05/06/13 12:30 PM Re: Most common socket size and screws on 2007 MDX [Re: cadfaeltex]
ajchien Offline
Loc: los angeles
As far as I know, JIS screws are still being used. I'm still seeing them scattered all over the place.
However. There are many screwdrivers now that are no longer marked or advertised as JIS, because many "exceed JIS" specifications. It's hard to know which manufacturers "exceed JIS" and which are regular Phillips. Really annoying.
Total pain in the butt if you're a bit compulsive about using the right screwdrivers.
#2994606 - 05/06/13 12:42 PM Re: Most common socket size and screws on 2007 MDX [Re: cadfaeltex]
cadfaeltex Offline
Loc: KS
Having a car full of Pozidriv (and torx) I've become compulsive lol. Found a set of JIS Vessel screwdrivers I might get. They have a set of 'impact' screwdrivers that act like a impact driver that look pretty cool as well.
Page 1 of 2 1 2 >
