anybody good in theorycrafting mathematic?
by yvon_la
05/24/16 06:51 AM
Aeroshell 22 v Mobil 28
by rooflessVW
05/24/16 06:36 AM
QSAD 5W20 VOA Bottled 2/25/16
by dustyroads
05/24/16 06:29 AM
What polish/wax to apply before Collinite 845
by pennzoil_guru
05/24/16 05:46 AM
Native American Advertising
by tony1679
05/24/16 05:45 AM
Akebono ProACT ceramic pads
by dlundblad
05/24/16 04:37 AM
3D printed plastic lower receiver
by Merkava_4
05/24/16 04:19 AM
How to install an AR-15 in your F150
by Merkava_4
05/24/16 03:39 AM
12 quarts Redline 5w30 $96.00 York pa area
by spiderbypass
05/24/16 03:00 AM
Trying to prevent high mileage leaks
by twincam00
05/24/16 02:04 AM
food depot
by urrlord
05/24/16 12:13 AM
Re-surfacing original GM wheels
by HM12460
05/23/16 10:28 PM
WeekendWarrior, emily, lex73, showstopr30, any_user
57966 Registered Users
75 registered (2015_PSD, badtlc, 2009Edge, Bandito440, Al, 1foxracing, 7 invisible), 975 Guests and 124 Spiders online.
57966 Members
66 Forums
249332 Topics
Page 2 of 2 < 1 2
#2535726 - 02/13/12 09:29 PM Re: A Chemistry Term Paper On My UOA [Re: Lethal1ty17]
Carbon Offline
Loc: near Chicago
I suggest comparing the spectral analysis to the classic flame tests of qualitative analysis in chemistry. The flame tests are limited to the more easily ionized elements, but there is a relationship. I presume you did flame tests in lab.
Edited by Carbon (02/13/12 09:39 PM)
#2685226 - 07/16/12 01:53 AM Re: A Chemistry Term Paper On My UOA [Re: Lethal1ty17]
lubrex1 Offline
Loc: united arab emirates
hi,
i recently bought an ICP for elemental analysis, Is there any body who could guide me about element's wave lenght selection etc.
#2994493 - 05/06/13 10:24 AM Re: A Chemistry Term Paper On My UOA [Re: Lethal1ty17]
DriveHard Offline
Loc: Middle of Iowa
Seems to be a glaring error...
You stated
These rings have to reliably create a tight seal between the piston and the cylinder wall while travelling at up to 4,000+ feet per second
WOW! If that were the case, there would be thousands of sonic booms in our engine all the time!
I think you meant FEET PER MINUTE.
Nice work though.
Smile, it increases your face value.
2011 Silverado Crew Cab LT 6.2L/6spd
2008 BMW X3 3.0si Sport
Elio...?
#3931693 - 11/28/15 06:54 PM Re: A Chemistry Term Paper On My UOA [Re: tinmanSC]
Ducked Offline
Loc: Taiwan
Originally Posted By: tinmanSC
"This is basically the temperature at which the oil sample will start to combust in °F." Consider removing "basically" as it makes the definition sound ambiguous.
Perhaps also consider NOT using °F. Centigrade looks more scientifically literate.
"and dirt that gets sucked in through the engine’s intake system." Technically it gets blown in, as a reduction of air pressure in the intake causes the high pressure outside air to push it's way into the intake. But, perhaps this is best left uncorrected. smile
Indeed, because if you "corrected" it, you'd have to explain your "correction", and then you'd look like a pedant.
"The TBN (Total Base Number) is a lubricant’s reserve alkalinity measured in milligrams of potassium hydroxide per gram of oil." The reserve additive can also so be Calcium Sulfonate.
Leave it alone. You're saying how the reserve alkalinity is measured. Doesn't matter in that context what the reserve additive is
#3931738 - 11/28/15 07:39 PM Re: A Chemistry Term Paper On My UOA [Re: Ducked]
Ducked Offline
Loc: Taiwan
Or even Celsius.
(showing my age)
Page 2 of 2 < 1 2
