Hi guys,
- above 80 kmph at the point of loading (acceleration) and unloading (deceleration w/o using break) there is a slight singing / whining from the rear
- the same singing is present in idler neutral gear between 80 and 100 kmph (just as additional info)
I dont know if it comes from diff or it is tramsmmitted from gearbox via power train - rear axle to car body.
What is possibly the best / most successfull diff lube to try to get rid of the slight noise ?
Who has experience ?
In car manual is recommended:
temp < -30 °C SAE 80
-30 < temp < 30°C SAE 90
temp > 30 °C SAE 140 °C
temps here are between -20°C in winter and 35°C in summer.
thanks for answer
thanks for answer
