Greetings.
I have a motor oil leak in my -95 K2500 6.5d after the oil cooler lines were changed - the mechanic apparently did not bother to change the seals and it leaks now considerably.
I have unfortunately zero literature available and I'm at mercy of the Net but this is the situation:
my oil cooler is of the type which has threaded "joints" for the lines ie. not quick couplings. Are there O-rings between cooler and lines or flat seals?
AC Delco's site gives with my VIN a seal 463015 and elsewhere I get 14055585. Is this perhaps correct info?
