Originally Posted By: Hokiefyd
Originally Posted By: BlueOvalFitter
I would almost bet my life that you own a Glock pistol.
I don't. I do own a Ruger, though. And you actually haven't challenged me at all. You see, I don't write the Honda service interval recommendations. I simply do my best to explain them to others who may not understand the rationale behind them. If you have a problem with Honda's service recommendations, you'll have to speak with a Honda engineer.
You can't afford to buy a new filter at every OCI, and I do use a new filter at every OCI.
For someone demanding so much data and evidence from everyone else, you sure do seem to make a lot of (incorrect) assumptions! For your reference, here's my stash of filters at the moment. There are five (5) OEM Honda filters, two (2) Purolator L14610s, and three (3) Purolator PL14610s. That's a total of ten (10) filters. I can use them up as often as I like. I am comfortable with using one every other oil change. You are not. And that's cool. We can disagree without (incorrectly) assuming something about someone else's financial means.
So why are you so filter stingy when it comes to an OCI? Is it having to crawl under the car that is so difficult?
Use them filters man! At the rate you're going you WON'T be able to get under your car to use all of those filters.
That, or you are saving them and buying more to be on that new show called, "BITOG Hoarders."
