I'm not sure how many people are affected by this, but quite a number of people that drives Honda manual has complain about the CMC will grind and squeak as it ages. This affects Civic(myself)/RSX/TSX and maybe even TL.
Usually Honda just lube the cylinder by spraying some white lithium inside, but that only last a period of time before it returns. They will then, depending if car is still in warranty, replace the CMC. I am personally on my 3rd CMC now in a 7 year old car and don't have warranty anymore.
I want to stay away from white lithium as it doesn't seem to work when I tried to fix my 1st CMC.
The current CMC I have, it came with this pink grease which I don't know what it is.
Anybody have any good suggestion of what type of grease to use and hopefully last long enough(1 yr or so is good).
Keep replacing CMC even under my cost doesn't seem like a good solution.
Thanks all.
Thanks all.
