Just to try and wrap this up; none of the engine oil performance categories (API, ACEA) have any zinc control limits. Only in recent years have there been ANY chemical limits and, where they are introduced, they are on phosphorus (as well as sulphur and sulphated ash). Some have only a maximum limit, a few include minimum limits.
ACEA C3 has a phosphorus limit of 700-900 ppm. You may be able to imply zinc limits based on that, since Zn ratios tend to be fairly well-defined, but different ZDDPs have different ratios, so without knowing exactly which is in use in any given formulation, you'll get nothing more than a best guess.
