k...here's the scoop RE: piston to bore clearances.
Excessive bore-to-piston clearances, you'll not only get piston skirt rocking inside the bore (similar sounds as piston skirts slapping when cold due to excessive clearances), but you'll also get yourself onto trouble of possible piston seizure due to insufficient piston to bore contacts (yes, it does need to have some "touch" to help dissipate the heat from piston).
On 2T engines: excessive piston-to-bore clearances (typical shadetree mech tricks that still in-use today) will lead to piston seizure; too tight of the clearances may also lead to seizure also.
Optimal clearances have long been established in the area of IC engine designs, and just like piston ring-gap clearances: piston-to-bore clearances hasn't change much during the past 20 to 30 years and I believe these shall remain as-is until they go into the history book.
automotive engine R&D team constantly finding ways to reduce friction (energy saved in friction reduction in engine rotating components equates to fuel savings&/improved energy conversion). Thus the tricks of pulvrerized Moly on piston skirt coatings (Honda), reduction in Piston skirts area, and may other tricks that previously not used, or tricks that previously deemed too costly/unaware of.
Q.
Ask me how I knew this subject for I've done work on Suzuki engines (4cycle, overbore the cylinder bore, lead to cold piston slapping; air-cooled 2T engines overbored which lead to seizure, etc.)
