Just thought I would share
Last summer, I tried using used veggie oil as a bar and chain lube for my chainsaw. Did not work at all. I thought since it worked so well on other applications, it would be great for my bar and chain. Here's what happened.
Filled chainsaw with canola oil that had seen a couple of chicken and fish fries, (it had been filtered through old shirt).
Fired up chainsaw and started cutting wood, (pine and oak). In about 20 minutes, I noticed a sticky build-up on the top of the bar, about an inch beyond where the chain comes out from under the cover on the side of the motor. Tip of bar and bottom of bar totally dry. Shut down saw and noticed entire chain covered in sticky substance. Disassembled bar and chain, soaked chain in gasoline and cleaned. Soaked bar in gasoline and cleaned. Emptied veggie oil from chainsaw, filled oil tank with gasoline and ran without bar and chain until all gas had pumped through system, (took a minute or two). Refilled with bar and chain oil and worked fine.
My experience tells me using used veggie oil as a bar and chain lube does not work. Anyone else have any success?
By the way, I use used motor oil as my bar and chain lube and never had any issues.
