I can't find thread for my post on sludge, but a reply said it's too difficult to remove sump on some cars. So here is what I have done to clean sump and oil pump intake, when cross beam in the way etc:
1/ Buy or find a used plug for sump.
2/ Drill big hole through it and use hardware store brass fitting to connect hole to hose long enough to allow a funnel that can be held up high.
3/ Drain oil and then screw in new modified sump plug.
Safety: Disconnect battery, earth car and NO SMOKING as fumes in engine are explosive!
4/ Hold funnel up high and add a few litres of solvent (Acetone works) after you calculate how much will be enough to cover pump intake screen, but never touch the sump gasket. Check engine plans for any O rings that might be damaged by solvents if engine has oil level gauge.
5/ Leave for a while (Lunch break), but put out no smoking signs.
6/ Lower hose and place in container to drain sump, passing through old sock to filter out sludge, then lift up, fit funnel and pour in solvents again.
7/ If bad change solvent and do the flush again.
8/ Drain and then remove traces of solvent by adding several litres of cheap oil, then draining again. That will remove all traces of power solvents.
9/ Put back original plug and fit new filter (Removed after initial drain)
10/ Throw away oily socks and dispose of solvent correctly.
