Originally Posted By: HTSS_TR
I like to measure power consumption of a fully charged battery in maintain/float mode.
I expect that the current draw from the wall outlet is in tens milliamps when the charger is in maintain/float mode, so the power consumption should be less than 6-8 watts. Also, the power consumption of a timer should be known to see if you hook up the charger with timer on for 4-5 hours do you save power or not.
Id never put it on a timer. This makes the charger go through a full charge cycle each time, taking the voltage up higher than needed. It would be much better to have one with good current control to very low levels, and then just leave it on.. If I were putting it on a timer, Id do it much less often, like a week on then a week off.
