I got a question...
On toyota/scion vehicles, there are rubber o-ring bushings on some of the sliding pins for the calipers. On the front, only the bottom one I believe has it... On the rear, both do if I remember correctly.
When I did my brakes a few months ago I had big problems with the pins seizing up in the rear. Once I got them un-stuck, cleaned, relubed, replaced the pins and bushings, etc... I noticed there was much more resistance with the bushings on (I am sure by design)... Because the calipers were all seized up, there is more resistance than normal I believe.
Either way, they did slide properly after the fact but not as easily as the front ones. I removed the bushings and tested the operation without and they worked extremely well with little to no resistance at all.
But I figured that bushing had to be there for a reason so I made sure to keep them in and just lubed up as much as I could with sil-glyde (the permatex purple stuff seized them shortly after the first time... Don't use that stuff with any rubber).
My question is, are those bushings absolutely necessary? I plan to check/lube the brakes before winter again and want to hear some opinions on these... If they help the rear brakes function better (less resistance with the pins) should I remove them? When doing my dad's Prius brakes, I noticed his rear brakes had the slot for the bushings, but with no bushings present (nobody ever serviced them before me). So I am guessing it won't cause any damage if Toyota practice this on their other vehicles.
Just looking for some thoughts though... What is the function of these bushings anyway? Noise?
Thanks!
Thanks!
