quote:
This thread makes me wonder something. With my 2002 Grand Am, the first winter I had it I never got any winter startup noise, even -20 temperatures wouldn't create any kind of extra noises within the first 10 seconds. The second winter I had switched to a synthetic (Mobil 1 5w-30 SuperSyn), I had startup noise if it was below 5 degrees F. Then this winter I started it at 10 degrees F with a 15w-40(Rotella T) and didn't get any startup noise, although the starter did crank slower. Then I switched it with this winters winter oil, Amsoil 5w-30 and the next day it was the 15 degrees and I noticed a little bit of the noise I noticed with Mobil 1, and if its -5 degrees F or colder it will make a destinct groan for 10-15 seconds and suddenly stop making the noise. I'm considering Halvoline 5w-30 or 5w-20 that I used to do without that noise. There would have to be some kind of wear happening with that noise. I suppose that the increased piston slap with synthetics isnt making more wear but it makes me wonder why it is there. It confuses me.
